03-17-2008 07:46 AM
I have problem with three things: -1) SSL offload, -2) probe, and -3) server redirect.
1) I made SSL offload like shows attached file with "show run". But during going to the VIP address by the browser: https://192.168.254.143 I get window with Java error: java.lang.NullPointerException - I have to click OK on this window and then can work fine. Without SSL offload I don't have this error message in window.
When I have SSL offload I have following configuration:
ssl-proxy service SSL
key klucz.pem
cert certyfikat.pem
serverfarm host SFARM
rserver S1 8080
rserver S2 8080
policy-map multi-match SLB-POLICY
class SLB
ssl-proxy server SSL
Without SSL offloading I have only this:
rserver S1 (without 8080!)
rserver S2
2) Right now I have two real servers and I send traffic to them by port TCP 8080. So I made probe to check TCP 8080 port availability.:
probe tcp TCP_8080
port 8080
interval 15
passdetect interval 60
rserver S1 8080
probe TCP_8080
inservice
rserver S2 8080
probe TCP_8080
inservice
I want also check port TCP 6400 availability, and I only one from port 8080 or 6400 don't work - make real server unavailable. So must work TCP port 8080 ang 6400 togethet to treat real server as operational.
So I want to make something like this:
probe tcp TEST
port 8080 and 6400 !?! - ofcourse It is impossible but I want to make config with this functionality.
How to do this?
3) I hant to make that when I write in browser https://bo.kw.coig.biz/ = https://192.168.254.143 I want to be redirected to one of real server on address: https://bo.kw.coig.biz/businessobjects/enterprise115/desktoplaunch/InfoView/logon/logon.do
I made something like this:
rserver redirect S3
webhost-redirection https://%h/businessobjects/enterprise115/desktoplaunch/InfoView/logon/logon.do 302
inservice
serverfarm redirect REDIRECT
rserver S3
inservice
policy-map type loadbalance first-match POLICY-TYPE
class class-default
serverfarm REDIRECT
But this configuration dosn't work. I have in browser window with error messeging.
How to do this?
03-18-2008 06:34 AM
1/ this is a java problem.
Java is telling you that it attempted to use a null pointer. You need to check with the people who created the java program
2/ you can configure multiple tcp probe, one for each port you need to monitor and assign all the probes to the serverfarm.
BTW, you can assign the problem to the entire serverfarm so you don't need to specify it for each rserver.
3/ the problem with your redirect is that you applied to class-default.
So even a request to ...../logon will be redirected to ...../logon.
Therefore you just created a nice loop.
You need to create a class-map to only match the url "/" so the redirect is only applied then.
Gilles.
04-10-2008 04:29 AM
Thank you,
Regarding server redirect:
could you write me example of configuration this specific class-map? And when use this class-map in which policy-map?
Regarding java error - this aplication is Business Objects an SAP so I think that there is not big probability that this is java error.
