Associate VLAN over both ACE and FWSM
wim.juste
Is it possible to have a vlan associated to vlan-group of both ACE AND FWSM ?
For example to let ACE connect to a management vlan which is firewalled by the FWSM.
Thanks a lot!
Greetings, Wim
Roble Mumin
Level 3
Level 3
Yup it is possible. I have a similar setup which works fine. A good thread explaining this can be found under following link.
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Data%20Center&topic=SNA%20Data%20Center%20Networking&CommCmd=MB?cmd=pass_through&location=outline@^1@@.1dddee0b/0#selected_message
I suggest you separate the vlan-groups/firewall-groups into FWSM only, ACE only and shared Vlans.
Roble
