11-20-2003 09:35 AM
Is there a way to stop one web site from being cached? The customer updates there web page, then goes to it but it shows the old page. Only from inside there network. The outside world sees the updated page. Cache engine Version: ce507-5.0.3
Jerry Larson
11-21-2003 12:10 AM
Hi Jerry,
there are several possibilities:
1) Check if the CE send an If Modified Since (IMS) Message to the server and check if this message is answered properly by the server. If the answer of the server is missing you know what went wrong. If the IMS Message is missing we now where to seach further. This knowledge would be good as guys in the outside which are using a proxy could have the same problem...
2) Use a rule in your CE which says the Content from this server is not cached
3) Is the server telling to clients at the outside that this page has not to be cached (don't cache flag)? And are you having a rule which is ignoring this don't cache flag.
Hope that helped for the first troubleshooting.
Regrads,
Joerg
11-21-2003 09:52 AM
Thanks, I found the rule command after I posted this message.
Jerry
