Cisco CSS Load Balance Issues
bronocode
I'm still relatively new to Cisco CSS' so I may not be using the right terminology.  Anyways, I'm testing out a 2 Windows 2008 IIS7 web servers in a load balance configured on the CSS.  The site uses a login to authenticate and I've configured the Machine Key in IIS7 to match on each server.
Unfortunately, this doesn't seem to be working and I'm having a hard time figuring out why.  I figured I would try using a sticky instead from the CSS side.  I want to use advanced-balance arrowpoint-cookie method over srcip as I feel like using a IP-sticky has it's faults (please correct me otherwise).  Anyways, the cookie is working and I stay connected through one server, however the site is extremely slow and it doesn't always authenticate properly.  The page will hang and it will eventually time out and bring you back to the main login page.  If I host file one server, it works fine.
Now - there may be something on the application side and still exploring that avenue, but we had issues with VIP even when there was just one server in the mix.
I believe we have the Cisco 11500 series
8 Replies 8
Jorge Bejarano
Level 4
Level 4
Hello DD,
Do you have it configured as L5 content rule?
Can you upload the owner, content rule, services and groups(If any)?
At this point, stickiness is working fine however you are seeing slowness and some timeouts, correct? If you are having some timeout, maybe you may need to configure a "flow timeout multiplier"
Is this a http or https site?
Additionally, it may be related with window scale, does your servers or client use it?
Please let us know
Jorge
Please include your current version as well
Jorge
bronocode
Here is what is currently setup:
content vip19-80
    vip address XX.XX.XX.XX
    balance leastconn
    port 80
    protocol tcp
    add service XX.XX.XX.01-80
    add service XX.XX.XX.02-80
    active
For now, this is strictly HTTP.  Please forgive me as I'm still learning this.  It appears I'm not using a L5 Content Rule.  Is L5 pretty standard to use for web applications (particularly .NET if that makes a difference)?
And by version, do you mean the software version?
Thanks!
Hi DD,
Yes software version.
Your configuration requires this:
content vip19-80
    balance leastconn
    port 80
    protocol tcp
    URL "/*" ------------------> it seems you are missing this part
    active
Please test it and let us know how it behaves after applying the change
Jorge
Rhe URL command is not mandatory.
If your site is slow, you should first check if it slow only when using SSL or if is also slow when using the clear text vip.
Get a sniffer trace frontend and backend to see where there is delay.  Could be a problem with window scaling.
Gilles.
bronocode
Still having an issue after adding the L5 content rule.  Here are the current configs.  We are on version 08.20.5.01
content vip19-80
  vip address xx.xx.xx.110
  balance leastconn
  add service xx.xx.xx.01-80
  add service xx.xx.xx.02-80
  port 80
  protocol tcp
  url "/*"
  active
  ip address xx.xx.xx.01
  protocol tcp
  port 80
  keepalive type http
  keepalive frequency 10
  active
  ip address XX.XX.XX.02
  protocol tcp
  port 80
  keepalive type http
  active
I know this is a generalized question but is there an overall issue with Windows 2008 web servers being load balanced?
Hi DD,
Hummm, did you check what the WS of the client side and servers side are?
Jorge
Could you elaborate on your question?  I'm not quite sure what you're asking.  I've host filed each web server individually and have no issues.
