Connecting oracle database with sql*net via VIP on Ace
Is there any way to get oracle Database traffic working only via the ACE Blade instead of using a firewall to do packet inspection.
The case is we have application servers in a DMZ wich should connect via a VIP to a Oracle database on port 1521.
Normally oracle negotiates the tcp ports wich it will use and a normal firewall will do an inspect and opens up the dynamic channel.
However on the Ace there is still no Inspect for Sql*net.
Everthing on routing and connection level works fine tnspings telnet to 1521 works fine. Only when using the application stack the dynamic ports needs to be used.
In our design a firewall in between this node's is at this moment impossible.
Any Ideas or examples how to solve this...
Everyone's tags (5)
539
