09-19-2006 01:34 PM
I need to convert a CSS 11506 interface to a trunk. My question is do the CIRCUIT VLAN id numbers need to correlate with catalyst VLANs?
I did not use the switch VLAN numbers on the CSS. I used VLAN 1 (server side) and VLAN 2 (client side). These actually correlate on the Catalyst switch to VLAN 621 and 620 respectively. I have a pair of CSS setup for active/active using VIP and virtual-router/redundant interface failover.
The server side will now need to support a trunk. The catalyst switch server side VLANs are 621 and 622 (new).
If I must have CSS VLANs the same as catalyst then I assume I need to blow away CIRCUIT VLAN 1 configuration and create two new CIRCUIT VLANs on the CSS for 621 and 622. The relevant virtual router/interface redundancy would then be applied to these. Only after that I create a trunk interface and assign these VLAN.
The CIRCUIT VLAN configuration is below:
circuit VLAN1
ip address 192.168.21.10 255.255.255.0
ip virtual-router 1 priority 102 preempt
ip virtual-router 2 priority 101
ip redundant-interface 1 192.168.21.12
ip redundant-interface 2 192.168.21.13
ip critical-service 2 SRVWC20P80
ip critical-service 2 SRVWC21P80
ip critical-service 1 SRVAS28P443
ip critical-service 1 SRVAS29P443
ip critical-service 1 SRVAS26T443
ip critical-service 1 SRVAS27T443
ip critical-service 2 SRVWC30T80
ip critical-service 2 SRVWC31T80
Solved! Go to Solution.
09-20-2006 05:51 AM
yes, it needs to match the catalyst if you want to trunk, because now the CSS will pass the traffic with the vlan tag to the switch.
So, you will need to change your circuit vlan.
Gilles.
09-20-2006 05:51 AM
Gilles.
09-20-2006 07:57 AM
thanks Gilles
