Community Member
CSM Probes went down for 15 minutes
Hi all,
This morning all the probes went down on the csm module for exactly 15 mins and then came back up. There has been nothing else in the logs to indicate whey the went down. I have found a watchdog process which i think might have started back up the process for SLB. Has anyone ever come across this and what was the reason that the probes stayed down for exactly 15 mins.
Cheers
Kev
1 REPLY
Bronze
Re: CSM Probes went down for 15 minutes
A possible workaround is to reset the card from the SUP console.
Try:
http://www.cisco.com/en/US/products/hw/switches/ps708/prod_release_note09186a00800fe64c.html
116
