CSM to ACE module migration bridged
Has anyone experience with migrating csm module to ACE module in a Cat6500 using bridge mode ?
I can migrate on a per vlan basis but would like to know if migrating on a per vserver would be possible in bridge mode ?
here is what I get when I configure both blades :
1w2d: %CSM_SLB-4-TOPOLOGY: Module x warning: CSM has received a packet that it may have transmitted. This may indicate a bridge loop
Thanks for your help.
Luc
Re: CSM to ACE module migration bridged
If you are migrating from csm to ace, have you tried the conversion tool csm2ace ?
it is available from the ACE GUI.
http://
Not sure why you are concerned about csm error message if migrating to ACE ?
G.
Hi G.
the problem is that as both blade are bridging the same vlans, they create a loop and we cannot migrate all our services on 1 go so both blade must coexist.
I also checked the conversion tool for the config and it seems to be quite good ;-)
what I would like is to have the both csm and ace bridging in order to migrate 1 Virtual server at a time.
BTW are you going to networkers Barcelona ?
Configuring 2 devices in bridge mode without spanning (the loadbalancers do not do spanning-tree) is for sure going to create loops.
I just don't know how you could easily migrate in such a scenario.
No Barcelona for me.
Haven't been to Networkers for many years.
Not sure why they think software engineers are not supposed to be there :-)
G.
Thanks for your reply anyway, I think we will migrate on a per vlan basis then ;-)
You should be at networkers for the "ask the experts" session for data center application networking.
521
