04-11-2006 11:09 PM
hi everyone
i have a question about css 11050
there are three web servers(1.1.1.93,96,97) and db server (1.1.1.90) in same vlan.
loadbalancing is working well.
but sometimes qeury data from webserver to db returns zero. not always.
i attach a some config file and topology
anyone who experianced this problem reply to my post ..
thanks in advance.
Solved! Go to Solution.
04-11-2006 11:29 PM
what kind of connections exist between web servers and db server ?
Is it permanent tcp connection ?
Or is it open - query - close ?
The problem could be the css timing out the connection.
If you know which port is being used for the db connection, try the command 'flow permanent portX XX'.
Gilles.
04-11-2006 11:29 PM
Gilles.
04-11-2006 11:37 PM
thanks gilles.
tcp connection is open-query-close
and db sevice port is 1433.
ok. i will test your suggestion today
