02-14-2003 07:24 AM
We are trying to load-balance print server connections between 2 MS print servers. When we try to connect to the print servers name, (\\PS01) or even the VIP address, we get a Path not found error. However, if we direct the path to the actual name or ip address of the print servers (not the VIP), we can view all the queues and connect/print to them. Is this possible to do on the CSS 11503? Thanks.
02-14-2003 07:31 AM
Ok, couple of things here
1. Is the default gateway of the print servers the CSS ?
2. Are the print servers responding back directly to the client machines, In other words is it possible you need to NAT the servers using a source group that would NAT the servers response to the VIP address
group printservers
vip address 10.1.1.1
add service pserver1
add service pserver2
active
Pete Knoops
Cisco Systems
02-14-2003 07:35 AM
Pete- Here is our config. See any problems?
configure
!*************************** GLOBAL ***************************
ip route 0.0.0.0 0.0.0.0 1.100.100.100 1
!************************* INTERFACE *************************
interface 1/2
bridge vlan 2
!************************** CIRCUIT **************************
circuit VLAN1
ip address 1.100.101.110 255.0.0.0
circuit VLAN2
ip address 10.100.249.1 255.255.255.0
!************************** SERVICE **************************
service ps01
ip address 10.100.249.5
active
service ps02
ip address 10.100.249.6
active
!*************************** OWNER ***************************
owner printserver
content L3_Basic
add service ps01
add service ps02
vip address 1.100.100.35
02-14-2003 07:41 AM
Josh,
Config looks fine. L3 rule should be fine. Is the default gateway of the print servers the CSS ?
You may have to do the following
group pservers
add service ps01
add service ps02
active
Pete..
02-14-2003 07:43 AM
Yes, the default gateway is the CSS Vlan interface 10.100.249.1/24. What is the difference between a group and a content rule?
josh
02-14-2003 07:47 AM
The group will perform NATing on the CSS. You want to make sure that responses from the PS get NATd to the VIP address as this is what the client station is expecting the response to come from
Pete..
02-14-2003 10:32 AM
Thanks Pete for the help. As soon as I added the group config, everything seems to work fine. Thanks again!
josh
02-14-2003 10:39 AM
Great News !!!!
Pete..
06-04-2003 10:19 AM
Sorry to bring this issue back-up, but how do you ensure that that the return traffic is being NAT'd back to the VIP? I think I am having the problem where the return traffic is being sourced from the real address.
