05-14-2009 11:12 PM
Hi ,
I am not able to telnet to my ace module please see the error/msg i see when i try to login:-
[Switch6500]$ telnet acemod2
Trying 10.10.10.2.
Connected to acemod2.asia.com
acemod2 login: admin
Password:
Context not found, called API timed out
Trying 10.10.10.2....
Connected to acemod2.asia.com.
Escape character is '^]'.
Error: context name (id:0) cannot be determined.
Any help on this will be highly appriciated.
Sum.
05-14-2009 11:29 PM
are you trying to telnet the Admin context or another context?
Can you try to access it via the C6500?
use following command from the supervisor of your C6500:
session slot "slot number of ACE module" processor 0
Does this work?
05-15-2009 01:00 AM
hi,
yes this works. Console works fine as well. In regards to telnet it was working fine before but dont know it stopped working now.
Reg,
Sum.
05-19-2009 11:32 AM
This is most likely a result of aclmerge process pegging cpu. from console do:
show proc cpu | inc aclmerged
see if processes are high.
aclmerge performance was improved in A2(2.x) code
10-28-2009 01:47 AM
Hi Letrenta,
Now I am facing the issue while try to get into the ACE from cat 6500 switch.
C6509#session slot 2 processor 0
What can i do now???
Sum
10-28-2009 11:04 AM
It looks as if you are hitting CSCsv98101
Did you reload the ACE module and see if it fixes it?
Syed
