Inband Health Monitoring
I have the Inband Health Monitoring in my CSM with sw 4.2(2)
health retries count failed seconds
and I see that the csm declare failed the server only if see the Reset. I'd like to know if there is the possibility to have the server failed still I don't see the syn ack, without using probe but only with Inband Health Monitoring.
thanks
Ira
Re: Inband Health Monitoring
Ira,
Inband health monitoring and probe serve two different purposes.
Inband is a basic mechanism that considers server failed ONLY when server sent back a RST or the server was timed out by the CSM because of no response.
For more advanced health monitoring, such as catching L4 or application layer errors, you then have to use probes.
I used the pending command under the virtual state and everything goes ok
Ira
129
