inband management on Nx 7010 without M1 card
For a distrib layer, I would want to create an inband management (in case of we are a issue on OOB mgmt, i means to have a 2960 HS) on Nx7010 chassis without M1 card (only F1 cards - layer 2). I could create a interfce vlan but the status of the interface is down/down.
I have an other 2 x Nx7010 pair with M1 card ; for this pair, i can connect the interface ; the inband interfaces is up/up
I have also 2 x Nx5596 pair  ; for these boxes, i can connect the interface ; the inband interfaces is up/up
Do you know a solution to get 1 interface vlan up/up on chassis 7010 without M1 card in order to have an inband connexion ?
many thanks for you assistance.
Nicolas.
1 ACCEPTED SOLUTION
Hi Nicolas,
Yes that is possible. You need to use management keyword on that L3 VLAN on F1 card. More info here:
http://www.cisco.com/en/US/partner/docs/switches/datacenter/sw/5_x/nx-os/interfaces/configuration/guide/if_layer3int.html#wp1611397
Nik
Hi Nicolas,
Nik
Hi Nik,
Thank a lot for this right answer + the URL.
Have a good day
Nicolas.
549
