Nexus 1000v management interface
not sure if this is the place to ask or not, if not if you can direct me to the correct place that would be great.
I have a Nexus 1000v on a esxi server. The server has two NICs that go to two different switches that are completely isolated from each other. I have a vSwitch set up that can access the vCenter, and a port from the 1000v is attached to that vSwitch - that uses NIC1.
NIC2 is attached to the 1000v in the UPLINK port-profile, and I can reach a bunch of hosts and the Vmk0 that I added to the Control Port-profile (maybe not the right place to add it - but it works)
here is the config of the 1000v
version 4.2(1)SV1(5.1)
no feature telnet
username admin password 5 $1$Aet3Mefy$sm3z3sbncQg27LkcYnVBH.  role network-admin
banner motd #SE-Demo - Nexus 1000v Switch - access prohibited#
ssh key rsa 2048
ip domain-lookup
switchname SE-DEMO
system default switchport
logging event link-status default
vem 3
  host vmware id 34393433-3239-5553-4531-33374e334134
snmp-server user admin network-admin auth md5 0x1e15a8540fff0563a2f843f1deb3009d priv 0x1e15a8540fff0563a2f843f1deb30
09d localizedkey
snmp-server community infoblox group network-operator
vrf context management
  ip route 0.0.0.0/0 10.120.18.1
vlan 1-15,100-104
vlan 1-15,100-104
port-channel load-balance ethernet source-mac
port-profile default max-ports 100
port-profile type ethernet Unused_Or_Quarantine_Uplink
  vmware port-group
  shutdown
  max-ports 32
  description Port-group created for Nexus1000V internal usage. Do not use.
  state enabled
port-profile type vethernet Unused_Or_Quarantine_Veth
  vmware port-group
  shutdown
  max-ports 32
  state enabled
port-profile type vethernet management
  vmware port-group
  switchport mode access
  switchport access vlan 101
  no shutdown
  system vlan 101
  state enabled
port-profile type ethernet system-uplink
  vmware port-group uplinkportprofile1
  switchport mode trunk
  switchport trunk allowed vlan 1-15,100-104
  channel-group auto mode on
  no shutdown
  system vlan 1-15,100-104
  state enabled
port-profile type vethernet Data-Centre1
  vmware port-group
  switchport access vlan 3
  no shutdown
  state enabled
port-profile type vethernet packet
  vmware port-group
  switchport access vlan 102
  no shutdown
  system vlan 102
  state enabled
port-profile type vethernet ServiceConsole
  vmware port-group
  switchport access vlan 100
  no shutdown
  system vlan 100
  state enabled
port-profile type vethernet control
  vmware port-group
  no shutdown
  system vlan 1
  state enabled
vdc SE-DEMO id 1
  limit-resource vlan minimum 16 maximum 2049
  limit-resource monitor-session minimum 0 maximum 2
  limit-resource vrf minimum 16 maximum 8192
  limit-resource port-channel minimum 0 maximum 768
  limit-resource u4route-mem minimum 1 maximum 1
  limit-resource u6route-mem minimum 1 maximum 1
  limit-resource m4route-mem minimum 58 maximum 58
  limit-resource m6route-mem minimum 8 maximum 8
interface mgmt0
  ip address 10.120.18.47/24
interface loopback0
interface Vethernet6
  inherit port-profile Data-Centre1
  description linux1, Network Adapter 1
  vmware dvport 540 dvswitch uuid "34 51 1c 50 66 b4 e6 28-c2 f0 e4 75 ca 92 5b 40"
  vmware vm mac 0050.569C.CE39
interface Vethernet7
  description ntp1, Network Adapter 1
  vmware dvport 117 dvswitch uuid "34 51 1c 50 66 b4 e6 28-c2 f0 e4 75 ca 92 5b 40"
  vmware vm mac 0050.569C.CDE3
interface Vethernet8
  inherit port-profile control
  description Nexus1000V-4.2.1.SV1.4a, Network Adapter 3
  vmware dvport 1640 dvswitch uuid "34 51 1c 50 66 b4 e6 28-c2 f0 e4 75 ca 92 5b 40"
  vmware vm mac 0050.569C.CD99
interface control0
line console
boot kickstart bootflash:/nexus-1000v-kickstart-mz.4.2.1.SV1.5.1.bin sup-1
boot system bootflash:/nexus-1000v-mz.4.2.1.SV1.5.1.bin sup-1
boot kickstart bootflash:/nexus-1000v-kickstart-mz.4.2.1.SV1.5.1.bin sup-2
boot system bootflash:/nexus-1000v-mz.4.2.1.SV1.5.1.bin sup-2
svs-domain
  domain id 2
  control vlan 1
  packet vlan 102
  svs mode L2
svs connection vc
  protocol vmware-vim
  remote ip address 10.66.100.22 port 80
  vmware dvs uuid "34 51 1c 50 66 b4 e6 28-c2 f0 e4 75 ca 92 5b 40" datacenter-name Colo-Demo
  max-ports 8192
  connect
vsn type vsg global
  tcp state-checks
vnm-policy-agent
  registration-ip 0.0.0.0
  shared-secret **********
  log-level
Now comes my problem, I have a NMS attached to a c3750 on NIC2 that would really like to manage the 1000v itself however I can't figure out how to get the two to talk.
I've put the same network on basically all the Vethernet port-profile vlans, but can't get to the mgmt0 interface, and can't put ip address on anyother interface. It seems like it only wants to talk on interface two in the vmware host definition ... What am i missing
Any help would be great
tia
ken
Everyone's tags (2)
711
