One interface configuration for ACE4710
pt_wang
My customer they do not want change their real server IPs.
So I need setup one interace (one armed) for them on ACE4710.
Who had this sample configuration? (CSS has this but it seems to be not compitable with ACE)
ajayku2
here it is..
The configuration would be similar to routed mode it is just that you are applying SNAT.
rserver host S1
  ip address 192.168.0.200
  inservice
rserver host S2
  ip address 192.168.0.201
  inservice
serverfarm host SF-1
  rserver S1
    inservice
  rserver S2
    inservice
class-map match-all L4VIPCLASS
  2 match virtual-address 172.16.0.15 tcp eq www
policy-map type loadbalance http first-match WEB_POLICY
  class class-default
    serverfarm SF-1
policy-map multi-match VIPs
  class L4VIPCLASS
    loadbalance vip inservice
    loadbalance policy WEB_POLICY
    loadbalance vip icmp-reply active
    loadbalance vip advertise active
    nat dynamic 1 vlan 240
interface vlan 240
  ip address 172.16.0.130 255.255.255.0
  alias 172.16.0.128 255.255.255.0
  peer ip address 172.16.0.131 255.255.255.0
  access-group input any
  service-policy input REMOTE_MGMT_ALLOW_POLICY
  service-policy input VIPs
  nat-pool 1 192.168.0.254 192.168.0.254 netmask 255.255.255.0 pat
  no shutdown
Thanks.
Cesar Roque
Level 4
Level 4
Here is a configuration example of HTTP & HTTPS loadbalance in One-Armed Mode:
access-list Allow_Access line 10 extended permit ip any any
rserver host test
  ip address 10.198.16.98
  inservice
rserver host test2
  ip address 10.198.16.93
  inservice
serverfarm host test
  rserver test 80
    inservice
  rserver test2 80
    inservice
ssl-proxy service TEST
  key cert
  cert cert
sticky ip-netmask 255.255.255.255 address source group1
  timeout 720
  serverfarm test
sticky http-cookie test group2
  cookie insert
  serverfarm test
class-map type management match-any NSS-ACCESS
  10 match protocol telnet any
  30 match protocol icmp any
  40 match protocol http any
  50 match protocol https any
class-map match-all VIP
  2 match virtual-address 10.198.16.122 tcp eq www
class-map match-all VIPSSL
  2 match virtual-address 10.198.16.122 tcp eq https
policy-map type management first-match NSS_MGMT
  class NSS-ACCESS
    permit
  class class-default
    permit
policy-map type loadbalance first-match test
  class class-default
    sticky-serverfarm group1
policy-map multi-match clients
  class VIP
    loadbalance policy test
    nat dynamic 1 vlan 112
  class VIPSSL
    ssl-proxy server TEST
interface vlan 112
  ip address 10.198.16.91 255.255.255.192
  access-group input Allow_Access
  nat-pool 1 10.198.16.122 10.198.16.122 netmask 255.255.255.192 pat
  service-policy input NSS_MGMT
  service-policy input clients
  no shutdown
ip route 0.0.0.0 0.0.0.0 10.198.16.65
--------------------- Cesar R ANS Team
Thanks.
