Recommendation for host header regex
What would be the best host header regex for http://www.example.com? I like the first one below best for the look of the configuration file, but I guess the second or third ones would be the most accurate. Any ideas if it makes any difference for performance, functionality etc.?
match http header Host header-value "www.example.com"
match http header Host header-value "www\.example\.com"
match http header Host header-value ".*www.example.com"
Best regards,
Harry
167
