01-23-2007 05:56 AM
Hi, on our CSS running 7.50.03 we use custom scripts for service keepalives.
Whenever we change the script contents and upload it to the CSS, but do not rename it, the services are shown as down until we reboot the box.
Is there another way to change the script contents without needing a reboot.
cheers,
Mike
Solved! Go to Solution.
01-23-2007 08:19 AM
Mike,
once the script is loaded in memory, if you upload a new one it has no effect.
The only way to refresh the script from memory is the reboot, or remove the script from all keepalive/service and then reconfigure it.
Gilles.
01-23-2007 08:19 AM
Mike,
Gilles.
09-20-2007 04:24 PM
I am trying to edit script ap-kal-dns to support radius authentication requests going thru a CSS to ACS servers. What is the best way
