Community Member
script writing for keepalive for CSS11506
I need write a script for health check:
1. a tcp port
2. the backend server will send a banner which include "END".
I have changed a little about ap-kal-tcp-ports (an example in css docs)
function SOCKET_CONNECT begin
set CONTINUE_ON_ERROR "1"
socket connect host ${SERVICE} port ${TCP-PORT} tcp 2000
socket waitfor ${SOCKET} "end" case-sensitive
set SOCKET-STAT "${STATUS}"
set CONTINUE_ON_ERROR "0"
socket disconnect ${SOCKET} graceful
function SOCKET_CONNECT return "${SOCKET-STAT}"
function SOCKET_CONNECT end
service test
ip address 10.1.1.21
protocol tcp
port 2304
keepalive type script ap-kal-tcp-ports-jx "10.1.1.21 2304"
keepalive frequency 20
active
it is working for health check, but, it is not care if there is a "end" existed or not.
Could anyone advice me how can I check a string in keepalive responce from backend server?
Any comments will be appreciated
Thanks in advance
162
