SSL connection failures.
I'm getting some SSL connection failures on our SSL modules, we've reset the stats and noticed we are getting rsa pkcs pad errors when we do a sh ssl-proxy stats ssl. What causes these errors ?
SSL error statistics:
session alloc fails : 0 session limit exceed: 0
handshake init fails: 0 renegotiation fails : 0
no-cipher alerts : 0 ver mismatch alerts : 0
no-compress alerts : 0 multi buf rec errors: 0
ssl peer closes : 0 non-ssl peer closes : 0
unexpected record : 0 rec formatting error: 0
rsa pkcs pad errors : 2 premaster errors : 0
failed rsa reqs : 0 failed random reqs : 0
failed key-material : 0 failed master-secret: 0
failed update hash : 0 failed finish hash : 0
failed encrypts : 0 failed decrypts : 0
bad record version : 0 bad record size : 0
cert verify errors : 0 unsupported certs : 0
conn aborted : 0
overload drops : 0 hs limit exceeded : 0
hs handle mem fails : 0 conn reuse error : 0
dev invalid params : 0 dev failed requests : 0
dev timeout : 0 dev busy : 0
dev cancelled : 0 no dev fails : 0
dev resource fails : 0 dev unknown errors : 0
dev conn ctx fails : 0 dev cmd ctx fails : 0
mem alloc fails : 0 buf alloc fails : 0
invalid cipher algo : 0 invalid hash algo : 0
unaligned buf addr : 0 unaligned buf len : 0
internal error : 0 unknown ipcs : 0
double free attempts: 0 alert-send fails : 0
210
