08-06-2008 02:24 PM
Hello!
We are planning an IOS up-grade for a Cat6500 (SUP720).
Installed on chassis, we have a SSL Module with a ssl-proxi service, trustpoint and certs loaded.
Is there any risk to loose some or all SSL Module configuration (certs included)?
Do you know any other special procedure (other than simple "reload" or power supply off), with the SSL Module present on chassis?
Thanks in advance...
Pedro
Solved! Go to Solution.
08-13-2008 12:10 AM
Pedro,
the SSL module keeps its config and cert/keys onboard. So, upgrading the IOS on the Sup720 will not affect the SSLM.
Just make sure the new IOS supports the SSLM.
Gilles.
08-12-2008 05:54 AM
Go through this Catalyst 6500 Series Switch Content Switching Module with SSL (CSM-S) Installation and Configuration Note.
For configuration and installation assitance.
08-13-2008 12:10 AM
Pedro,
Gilles.
08-13-2008 06:44 AM
Thanks for your help Gilles...
We made the up-grade last weekend, and the switch and services are working ok.
Best Regards
Pedro
