SSL termination and Loadbalancing on the same CSS
I am trying to set up a CSS11503 for SSL termination and load-balancing to two servers. I am having problems with slow performance, I think due to stickyness. It would appear that a new SSL session is started for each request. I'll start by describing what I want to happen, and will finish with a description of the current config.
WHAT I WANT:
Connection comes from the internet, and SSL is terminated on single CSS. CSS then load balances (with stickyness) to one of two IIS servers. The load balancing must not be based on source IP as we potentially would have multiple users from a company coming from the one source NAT.
Once a client is connected, I need them to continue to go to the same IIS server.
i.e if the user is load balanced to server1, I want all subsequent traffic in that session to go to server1.
The website is run by an application team, so not 100% sure on the setup, but I believe that there are both ASP.NET session cookies and other cookies set, which could be used as the basis for load balancing.
OK, so that's what I want, here is WHAT I HAVE:
The setup is:
website.company.com = x.x.x.x
CSS VIP = y.y.y.y
Server1 IP = a.a.a.a
Server2 IP = b.b.b.b
Firewall has static NAT x.x.x.x <-> y.y.y.y
The network infrastructure is:
INTERNET -- FIREWALL -- CSS VLAN 1 (VIP and FW connect) -- CSS VLAN 2 (Web DMZ) -- Server1, Server2 etc
The relevant CSS config is:
content website.company.com_ssl
application ssl
vip address y.y.y.y
add service ssl
protocol tcp
port 443
active
content website.company.com_lb
vip address y.y.y.y
add service server1
add service server2
advanced-balance cookies
protocol tcp
port 81
active
! CSS SSL-PROXY-LIST EXCERPT:
ssl-server 16
ssl-server 16 vip address y.y.y.y
ssl-server 16 cipher rsa-with-rc4-128-sha y.y.y.y 81 weight 5
ssl-server 16 cipher rsa-with-rc4-128-md5 y.y.y.y 81 weight 10
ssl-server 16 rsacert website_cert
ssl-server 16 rsakey website_key
service ssl
keepalive type none
slot 3
type ssl-accel
add ssl-proxy-list ssl
active
service server1
ip address a.a.a.a
keepalive type http
protocol tcp
port 81
active
service server2
ip address b.b.b.b
keepalive type http
protocol tcp
port 81
active
Any help is much appreciated!
Andy
144
