Technical differences between ACE-4710-K9 & ACE-4710-BAS-SK-K9
Hi All,
Iam trying to find technical diff between ACE-4710-K9 with ACE-AP-01-LIC & ACE-4710-BAS-SK-K9 with ACE-AP-BAS-LIC.
Can someone shed some light..?
Thank you all in advance
MS
  • Application Networking
1 REPLY
Re: Technical differences between ACE-4710-K9 & ACE-4710-BAS-SK-
As per my understanding
Both will give you same functionality
ACE-4710-BAS-SK-K9 is a basic kit/bundle
that Includes:
- ACE 4710 Hardware
- ACE Software
- 1 Gbps Throughput License
- 1,000 SSL TPS
- 100Mbps Compression
- 5 Virtual Devices
Where as
"ACE-4710-K9 with ACE-AP-01-LIC" is kind of La Carte option
ACE-4710-K9 is the ACE Appliance Hardware includes(1K SSL TPS, 5 contexts, 100Mbps comp)
With it you need to select two mandatory options
ACE Software :ACE-AP-SW-XX Software Version XX
Throughput License :("ACE-AP-01-LIC" 1 Gbps OR "ACE-AP-02-LIC" 2 Gbps )
Then you can select optional licences for
SSL TPS, Virtual Devices, compression & App acceleration...(if you need to upgrade the defaults 1K SSL TPS, 5 contexts, 100Mbps comp)
Syed iftekhar Ahmed
983
