08-21-2012 05:14 AM
I try to use multiple certificates on a Cisco loadbalancer Ace. After some research, I think the best solution is to configure an IP with SSL (as default on apache) and therefore to manage the configuration of the loadbalancer.
Here is my current configuration of ACE:
show run
Generating configuration....
ssh maxsessions 1
access-list ANY line 8 extended permit icmp any any
access-list ANY line 16 extended permit ip any any
probe tcp PROBE_TCP
interval 30
rserver host SERVER1
ip address 172.16.0.1
conn-limit max 50000 min 40000
inservice
rserver host SERVER2
ip address 172.16.0.2
inservice
serverfarm host FARM_WEB
predictor leastconns
probe PROBE_TCP
rserver SERVER1
inservice
rserver SERVER2
inservice
parameter-map type http HTTP_PARAMETER_MAP
persistence-rebalance
class-map match-any HTTP
2 match virtual-address 37.59.XX.XX tcp eq www
class-map type management match-all PUBLIC_REMOTE
2 match protocol ssh source-address 193.252.XX.XX 255.255.255.255
class-map type management match-all REMOTE_ACCESS
2 match protocol ssh any
class-map match-any SSL
2 match virtual-address 37.59.XX.XX tcp eq https
policy-map type management first-match REMOTE_MGMT_ALLOW_POLICY
class REMOTE_ACCESS
permit
policy-map type management first-match REMOTE_PUBLIC_MGMT
class PUBLIC_REMOTE
permit
policy-map type loadbalance http first-match WEB_L7_POLICY
class class-default
serverfarm FARM_WEB
insert-http x-forward header-value "%is"
policy-map multi-match WEB-to-vIPs
class HTTP
loadbalance vip inservice
loadbalance policy WEB_L7_POLICY
loadbalance vip icmp-reply active
nat dynamic 1 vlan 2890
appl-parameter http advanced-options HTTP_PARAMETER_MAP
class SSL
interface vlan 1277
ip address 37.59.XX.XX 255.255.255.240
alias 37.59.XX.XX 255.255.255.240
peer ip address 37.59.XX.XX 255.255.255.240
access-group input ANY
service-policy input REMOTE_PUBLIC_MGMT
service-policy input WEB-to-vIPs
no shutdown
interface vlan 2890
ip address 172.31.255.250 255.240.0.0
alias 172.31.255.249 255.240.0.0
peer ip address 172.31.255.251 255.240.0.0
nat-pool 1 172.31.255.248 172.31.255.248 netmask 255.240.0.0 pat
service-policy input REMOTE_MGMT_ALLOW_POLICY
no shutdown
ft track interface VLAN1277
track-interface vlan 1277
peer track-interface vlan 1277
priority 50
peer priority 5
ip route 0.0.0.0 0.0.0.0 37.59.XX.XX
username XXXXX password 5 XXXXX role Admin domain default-domain
I thought to add two servers, and SERVER101 SERVER102 with IP addresses 172.16.0.101 and .102, and thus add a new external IP.
I have not looked too to change the configuration, but I do not think it poses problems.
My certificates are configured directly on my servers (nginx and apache2) not the loadbalancer.
Do you think this is the best solution?
thank you very much
08-21-2012 05:32 AM
It all depends on your requirement whether you want to offload SSL on ACE or on server.
Offloading on ACE will remove the burden of SSL encryption/decryption from the real servers’ CPUs, increasing the amount of traffic they are able to handle in most situations.
If you want to do it on ACE here is the document.
Siva
08-21-2012 06:46 AM
Thank you for this answer. I'm looking to set up the certificates directly to the loadbalancer.
08-21-2012 09:19 AM
The below links have sample config to setup SSL termination on ACE.
Siva
08-22-2012 01:15 AM
Hi and Thank for your help.
I have configure the first SSL and it's OK.
For the second, i just can had class in my policy map like that :
policy-map multi-match PROXYSSL1
class SSL1
ssl-proxy server proxy1
class SSL2
ssl-proxy server proxy2
Just another question, can i redirect the SSL trafic to port 80 after LB ? (i can configure apache / nginx to listen 80 and 443 without SSL but i just answer )
Thanks !
08-22-2012 01:19 AM
Yes that should be fine. To reditrect traffic on a different server port specify the port under rserver below.
probe PROBE_TCP
rserver SERVER1 80
inservice
rserver SERVER2 80
inservice
Siva
