Users losing session on 11500 series Content switches
What would cause users to loose session connection on the 11500 series switches.Arrowpoint cookies are been used.
1 REPLY
Re: Users losing session on 11500 series Content switches
the CSS has an aggressive way of destroying idle connection.
If a connection stays idle for 8 sec, the CSS mark it has idle.
Once marked idle, a connection will stay idle forever for the CSS - even if traffic is still going on between client and server.
So at some point of time, the CSS will decide to reuse the memory used to switch a connection marked idle.
At this time, the user will lose his session.
The solution is to increase the idle timeout.
The command is 'flow-timeout-multiplier' and you configure it per content rule.
Give it a try with a timeout multiplier of 20 and see if this improves the situation.
You may have to increase the value.
Gilles.
121
