03-04-2015 11:07 AM
We're running ACE SM 5.3(1) and I was wondering if the ACE would allow associating multiple VIPs with the same class-map?
Thanks.
_ Greg
03-04-2015 02:28 PM
That is possible, assuming you're talking about something like this:
class-map match-any CLASS-VIP-APPLICATION1
2 match virtual-address 10.10.10.10 tcp eq 80
3 match virtual-address 10.10.10.10 tcp eq 8080
03-04-2015 06:50 PM
Thanks for your response. What I had in mind is more like this:
2 match virtual-address 10.10.10.20 tcp eq 80
Thanks again.
03-05-2015 11:06 AM
Hi Greg,
Yes you can. You can also define a range:
switch/Admin(config-cmap)# 2 match virtual-address 10.1.1.1 ?
<1-255> Ip protocol number
<A.B.C.D> Specify virtual ip-address mask to use for a range of VIPs
Kanwal
Note: Please mark answers if they are helpful.
03-06-2015 04:59 AM
thanks much.
