03-06-2003 12:24 AM
My 7320 is halt. Can anybody give me some suggestion?
Thank you very much!
Boot info:
"Embedded services management firmware:5.22
.....................................:5.35
.....................................:5.32
(firmware out of date)
D0 ScanDisk SDP3B-128 Normal 122MB PIO 1
D1 not detected
D2 not detected
D3 not detected
IDE BUS Master Enable
CSCO
dbgrub_Start.S
Uncompressing Linux..
ran out of input data
--system halted.
03-06-2003 04:38 AM
Are you seeing this output on a pc monitor ? Is the console connected to the box because at some point the output on a 7320 switches over from the PC monitor connection to the Cisco standard console connection.
Pete..
03-09-2003 04:54 PM
Pete,
Thanks so much!
Following your suggestion, we showed some info using console.We entered '***' to rescue the system image.The Linux uncompressing is ok.But system still need a new system image.How can we get the new ACNS 4.1.1(for 7320)system image?Please tell me more .
Sha
03-10-2003 04:21 AM
Sha,
Depending on what version is currently on the 7320, these two links have the software you are looking for:
http://www.cisco.com/cgi-bin/tablebuild.pl/uce42-3des
or
Pete..
03-10-2003 11:11 PM
Pete,
Actually I have one ACNS 4.1.1 system iamge in one CE7320.But I do not know how to download it from CE7320 to my pc.You can tell me how to get it from CE7320 or give me detailed place to download it.
System image name maybe ce7320-ACNS-4.1.x-K9.bin.
Sha
03-12-2003 04:54 PM
Pete,
Sha
