Power Failure ?
  if power failure , Spam Block will auto restart after power resume ?
   or must manual turnon it ?
  thank
1 REPLY
Re: Power Failure ?
I am wanting to say that you will need to hit the power button but I am not 100 percent sure. I will get you a definite answer. The problem you run with the power failures is that it can corrupt your drives.
Brian
755
