Community Member
ATA 186 Configuration failed
I am trying to change my Ata 186 from a IOS that handle SCCP to a image that can handle SIP-communitation.
I have put the useTFTP to 0, and as you can see, tries to use the ata186us, to change the IOS. (See under) But, I only get "configuration failed". I have altso tried with several TFTP-servers, with the same result. Any suggestions?
Very grateful for any help! :)
Kaj
C:\Documents and Settings\NovaNett\Mine dokumenter\Kaj\KaMy\Cisco\ata18x-v2-16-1
-030709a-2>ata186us -any -d1 ata18x-v2-16-1-030709a.zup
ata186us version 2.0
Using Host: LapTopKaj with IP: 172.20.101.82 as upgrade server
This machine IP: 172.20.101.82
Upgrade Server Port: 8000
Data stream 0 port: 8500
image found: code -- ata186.itsp2.v2.16
Using dialpad of your telephone (attached to your ATA box),
press ATA button to go to main menu, and enter:
        100#172*20*101*82*8000# (to upgrade code)
NOTE:
Pressing 123# will announce your code's version number.
You can later verify that you have upgraded your ATA box.
This program runs continuously; Press <ctrl>-c to abort.
Upgrade server ready...
Thu Nov 19 09:47:20 2009 172.20.101.80  -> <udp: 172.20.101.82 8500 123>
Begin uploading code to 172.20.101.80 (Thu Nov 19 09:47:20 2009) ...
Done uploading code to 172.20.101.80 (Thu Nov 19 09:47:23 2009)
1 REPLY
Community Member
Re: ATA 186 Configuration failed
It been solved with another image version. I did excactly the same, but with version 3.2.1-sip. And it worked at once! :)
1333
