Auto-Dial delay with SPA122
I have an auto-offhook (Plar, Hot-Line) configuration set up on my ATA 122.  When I take the phone off-hook the ATA takes 3 seconds to place the call to the network.
My dial-plan entry is as follows:
<Dial_Plan_1_>( P0 <:4802788500>)</Dial_Plan_1_>
I've captured debugging level syslog from the ATA during the process.
*** I go off-hook and the following is generated right away (all within 100 msec) ***
[0]Off Hook
CC_eventProc(), event: CC_EV_USR_OFFHOOK(0x2), lid: 0, par: 0, par2: (nil)
AUD_ccEventProc: event 2 vid 0 par 0x0 par2 0x0
sysstatus_set_led_status_payton(), led_id: 1, statusCode:7, systemEvent: 0x100095
[IVR_eventProc] evt 2 lid 0
callEventProcTable[0] is cepIdleProc
cepIdleProc(line=0x1f90e8, call=0x1f90ec, event=9(CC_EV_USR_SEIZURE), par=0, par2=(nil))
cepIdleProc(), lid=0
cepIdleProc(), pname=proxy.adam.tnltd.net
cepIdleProc(), SYS_NOREG_CALL(0)=0, SIP_REGISTER_OK(0)=1
[AUD]Get UCH node for AUD_LINE 0 0.
uchAllocateNode(), Node 0 allocated
[AUD]UCH node 0 allocated to AUD_LINE 0.
uchConnectEpToNode(), connecting EP FXS 1 to node 0
uchEnableNode(), Node 0 enbaled
NEW_CALL_STATE(), call 0: old state = CC_CST_IDLE, new state CC_CST_DIALING
SLIC_stopRing
SLIC_startTone 1
uchSetMute(), ENABLE
*** There is then a 2.5 second pause ***
Set QoS succeed
callEventProcTable[1] is cepDialingProc
(The call is placed).
There is a 2.5 second pause between the "uchSetMute(), ENABLE" and the "Set QoS succeed".
Anyone have any ideas why the ATA is sitting there for so long before the call is placed?
-Adam
Everyone's tags (5)
1 ACCEPTED SOLUTION
It could be the Interdigit short timer, the default value is 3 seconds. Do you have already tried to reduce this value?
Regards.
Regards.
Daniele,
That was it, thanks!
-Adam
2650
