02-07-2018 09:27 PM - edited 03-21-2019 10:43 AM
My ATA232D is connected to Ubiquity Edgerouter X. I have other SIP phones on my network that can send and receive calls without issue. Since a few days I can not connect to incoming calls. Outgoing calls are still possible.
I have no changes to the spa or the router. Therefore, I find it strange that these problems have arisen.
I've already updated the firmware, and a backup restored from the period when everything was still working. This has not resolved the problem.
Any thoughts?
Solved! Go to Solution.
02-16-2018 01:48 PM
So sorry, it seems such interval is not configurable on SPA232D (I has used option value name related to other SPA* model). Just enable NAT keepalive (Line N configuration) and set "Register Expires" low enough to refresh NAT table of your router.
Unfortunately, we know no details of NAT configuration of your router thus we can just guess solution. Ask your local network administrator for help unless you know configuration of your NAT device.
02-08-2018 04:22 AM
It's caused by NAT and/or statefull firewall most of time. Make sure the value of NAT Keep Alive Intvl on SPA232D follows configuration of your NAT/firewall.
02-16-2018 01:25 PM
I've looked for the KeepAlive value. Any idea what menu it is under?
02-16-2018 01:48 PM
02-17-2018 08:42 AM
Thanks Dan, that did it. Thought I was going crazy looking for the settings but found these ones. All good. Cheers,
Alan
