certificates for PAP2T and SPA112
Hey there,
on behalf of a partner I have some questions/requests regarding PAP2T and SPA112:
  • •1.       I need a new SSL server license to the old PAP2t-eu unit since our old one has expired. (https)
  • •2.       I need the configuration guide(XML and TR-069) for the new SPA112 unit (without router)
  • •3.       I need a SSL server license for the SPA112 unit so that it can fetch it’s configfile over https.
  • •4.       Is there a way to tell the SPA112 via DHCP options where to locate the configfile or TR-069 address)
  • •5.       We already have finished config files for the PAP2t and wondered if there is a way to convert these to SPA112 compatible configfiles?
Your help will be much appreciated on this.
Kind regards,
Morten Ullness
1 REPLY
VIP Gold
  1. No, you need no certificate to connect to SPA112. If you are asking for server certificate (e.g. SPA112 is client) then read [1]
  2. I have reason to think there's no such option
  3. XML configuration can be used almost as-is. There are small differences related to router-configuraion part of SPA112 and some differences related to line configuration. Apply PAP2T XML configuration as is to SPA112 then re-download configuration from SPA112. Then configure SPA112 according your wishes, and fetch i's configuration again. COmpare two fetched configurations. You will see the differences.
419
