Cisco 3102 Voip & PSTN
Is it possible to have a 3102 have both PSTN and VOIP account while the PSTN accepts all inbound calls and all outbound local calls? I want to build a dial plan so that if a long distance number is dialed it will use my voip provider for long distance.
1 REPLY
Hello Sean,
This is definitely possible. You just need to configure the dial plans to route the calls out of either the PSTN or VOIP interfaces.
-john
726
