cisco 877 and spa122 registration issue
I have limited experience with both the spa122 and the cisco 877 and I am hoping someone can assist.
I am not sure if this should be in the IP Telpphony area but thought I would start here.
I was using a Zyzel P-2602HWNLI-D7A_1 ADSL 2 + modem with a SPA122, LAN, 2 FXS , 1.3.2 (014) May 9 2013 in Bridge Mode and my voip phone was working incoming and out going calls all ok.
I have now replace the Zyzel P-2602HWNLI-D7A_1 with a cisco 877 (Version 12.4(15)T14) and am having issues with SIP regestration using the spa122.
The error I am getting is :-
[LVS]Cannot resolve LVS_PROXY. Read lvs address from flash. IP =
[rse_refresh_addr_list] query sip.mynetfone.com.au block 1
uch_syncParameter start
What I think may be the issue is that my SIP dns name cannot be resolved.
From the Cisco 877 I can ping sip.mynetfone.com.au and it resolves so I think it may be an spa122 config issue??????
Any assistance will be greatly appriciated.
1 ACCEPTED SOLUTION
Re: cisco 877 and spa122 registration issue
Hi Domenic.
Does your SPA receive the ip address via dhcp or you have configured it statically?
In the first case check the dhcp pool config on the 877 , in the second case verify that you assigned the DNS correctly on the SPA.
In both cases you can try to use 8.8.8.8 as DNS which is the google one.
Carlo
Please rate all helpful posts "The more you help the more you learn"
I am still trying to find the issue so I enabled debuging of the SPA 122 and got the following:-
[0]->0.0.0.0:5060(569)
REGISTER sip:sip.mynetfone.com.au SIP/2.0
ect.....
tpError at [SIP_tsCreateClient:1789]
CC_eventProc(), event: CC_EV_SIG_REGISTER_FAILED(0x3B), lid: 0, par: 0, par2: (nil)
AUD_ccEventProc: event 59 vid 0 par 0x0 par2 0x0
SLIC_stopRing
SLIC_stopTone
[0]RegFail. Retry in 10
I also tried a ping from the SPA 122 to sip.mynetfone.com.au and it cannot resolve the address, I get the following error:-  Ping: Unknown host: sip.mynetfone.com.au
Can anyone assist??
Hi Domenic.
Carlo
Carlo
Thanks for the info you put me on the wright track, I was getting fustrated so I erased the 877 config and started again.
I intially confiured DHCP with the dns of 8.8.8.8, I was having same problem, then added the default route and it all worked.
The config that didn't work had my ISP's dns server, not sure if that was the issue as I was able to resole names from my PC.
Anyway it is always good to start fresh.
The config below works.
Current configuration : 3670 bytes
version 12.4
no service pad
hostname External
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1 192.168.1.32
ip dhcp excluded-address 192.168.1.44 192.168.1.254
ip dhcp pool Internal
   import all
   network 192.168.1.0 255.255.255.0
   dns-server 8.8.8.8
   default-router 192.168.1.1
   domain-name
   lease infinite
ip domain name mine.com
ip name-server 8.8.8.8
archive
log config
  hidekeys
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
pvc 8/35
  pppoe-client dial-pool-number 1
interface FastEthernet0
no cdp enable
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1412
interface Dialer0
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname
ppp chap password 0
ppp pap sent-username
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.1.0 0.0.0.255
dialer-list 1 protocol ip permit
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
scheduler max-task-time 5000
end
389
