Cisco SPA122 ATA with Router
lordg1984
I bought this beautiful object and I have a question: is there a way to block the dial out?
Patrick Born
Hi Gaetano,
So you purchased an analog telephone adapter (ATA) and don't want to make calls?
If this is the case, either:
1. disable the line
2. limit the dial plan
Either will stop it from making outbound calls.
Patrick---
    Use this reference document to locate SPA ATA resources
