Cisco Spa122 - Outbound calls are unavailable
jose.mneves
Hi all,
I'm trying to configure my new Cisco SPA122 and until now I can only receive calls. When I try to make a call the phone turn off immediately the call.
Is there any option that I'm missing, to let me make calls?
I have enabled port forward and even put the SPA122 on DMZ of my router Asus...
Can anyone help me?
6 Replies 6
Dan Lukes
Somewhat vague description of issue, thus countless possible causes ...
Wrong dial plan, firewall, misconfigured NAT, call rejected by provider ...
Turn on syslog&debug of voice application, capture SIP pakets between ATA and operator. It will help us to analyze the issue.
Hello Dan Lukes,
thank you for your fast reply.
I have turned on the Log and I got the message attached to this comment.
What exactly this message means?
Hello, I want to make a quick update but the problem still goes on. I can not make calls but I can receive calls.
- I have the most updated version of firmware: 1.4.1 (002) Oct 26 2015;
- I disable the service Bonjour and the error daemon.err have disapeared;
- At the moment the log does not describe any error;
- I had this voip number configured on a program X lite and it was working perfectly. Only when I configured on CISCO SPA122 it just don't work now;
What do you mean with misconfigured NAT? Which configuration probably is missing?
Do you want me do use wireshark? I don't have much experience with this program. I will try to search for the information you requested on this program.
So, I have installed wireshark but I don't find any error connection with the IP address of the CISCO SPA122.
Any tips?
Attached you can find the log file updated.
I have used today X-Lite again and with the program can make calls, so I know for sure that it is only Cisco SPA122 that can not make calls and can only receive!
Hello, Thank you for your help!
I manage to find the problem... The SIP port needs to be 5061 and I had another one :)
Thank you!!!
It's the system log. We need log of voice application (as mentioned). Read Debug and syslog Messages from SPA1x2
The messages needs to be sent to a computer running either syslog server or wireshark.(which can capture them as well). If you will use wireshark, attach the saved .pcap file (renamed to .txt).
