Cisco SPA8000 and SPA112
I have a few SPA 8000 and SPA112 TA's, and everything's OK, until I tried to transfer a call from one of this analog lines, it doesn't work.
For what I've saw on some info on the web, it's about configuration, but doesn't seems to work.
I'm located in Europe, and for example, in SPA8000, under regional settings/control timer values, I have:
Hook Flash Timer Min:  0.8
Hook Flash Timer Max: 1.2
How could I solve this?
The phones are several gigaset analog phones, desk or handset's.
Thanks in advanced,
Jorge Bastos,
Hall of Fame Super Gold
Wrong forum, post in "Small Business Voice". You can move your posting with the Actions panel on the right.
Thanks, done!
Is it possible to help now?
Hi, this is my working configuration:
Line Menu
Yes
Yes
Yes
Yes
Yes
Yes
AVT
Regional Menu
.08
SIP Menu
Yes
Regards.
Thanks for the answer.
With this, when I press the "R" key (tried with 3 different desk phones), the call hangs up.
Any idea?
Enable syslog and post debug.
Thanks.
Check:
I just answered the call, and pressed the "R" key and the call dropped, and got a new line signal.
Nov 1 06:58:33 SPA112 kern.warning [17191644.012000] In cordless Driver Codec 0 and str PCMU/8000 chan 0
Nov 1 06:58:33 SPA112 kern.warning [17191644.012000] In cordless Driver Codec 111 and str G726-32/8000 chan 0
Nov 1 06:58:33 SPA112 kern.warning [17191644.012000] In cordless Driver Codec 8 and str PCMA/8000 chan 0
Nov 1 06:58:33 SPA112 kern.warning [17191644.012000] In cordless Driver Codec 100 and str NSE/8000 chan 0
Nov 1 06:58:33 SPA112 kern.warning [17191644.012000] In cordless Driver Codec 112 and str encaprtp/8000 chan 0
Nov 1 06:58:33 SPA112 kern.warning [17191644.012000] In cordless Driver Codec 255 and str chan 0
Nov 1 06:58:34 SPA112 kern.warning [17191645.040000]
Nov 1 06:58:34 SPA112 kern.warning [17191645.040000] #### RTP STOP Flag set in this channel break ####
Nov 1 06:58:34 SPA112 kern.warning [17191645.044000] ###### sock_sendmsg return 172
Nov 1 06:58:34 SPA112 kern.warning [17191645.048000] In cordless Driver Codec 0 and str PCMU/8000 chan 0
Nov 1 06:58:34 SPA112 kern.warning [17191645.048000] In cordless Driver Codec 8 and str PCMA/8000 chan 0
Nov 1 06:58:34 SPA112 kern.warning [17191645.048000] In cordless Driver Codec 100 and str NSE/8000 chan 0
Nov 1 06:58:34 SPA112 kern.warning [17191645.048000] In cordless Driver Codec 112 and str encaprtp/8000 chan 0
Nov 1 06:58:34 SPA112 kern.warning [17191645.048000] In cordless Driver Codec 255 and str chan 0
Nov 1 06:58:36 SPA112 daemon.notice msgswitchd[205]: MSGSWD RTCP Reqt len 12 Data 2,1965716,7312,0
Nov 1 06:58:36 SPA112 kern.warning [17191647.052000] RTCP is running so calling rtcp stop
Nov 1 06:58:36 SPA112 kern.warning [17191647.052000] chan->kmode is present not null
Nov 1 06:58:36 SPA112 kern.warning [17191647.056000] ###### RTCP sock_sendmsg return 172
Nov 1 06:58:36 SPA112 kern.warning [17191647.060000]
Nov 1 06:58:36 SPA112 kern.warning [17191647.060000] #### RTP STOP Flag set in this channel break ####
Nov 1 06:58:36 SPA112 kern.warning [17191647.060000] ###### sock_sendmsg return 172
Can you try this config on a SPA8000?
Add logs.
Regards.
Don't have any atm with me
Only have them remotly, but can't do any test by calling/transfer.
Is there a way to make this SPA112 work?
Re: Cisco SPA8000 and SPA112
Hellou? cisco support?
I have about a hundred of this devices and none of them are working!!!!!
I payed for them, and I want support to make it work.
1769
