Community Member
Customize hookflash event body
I'm trying to integrate the ATA's hookflash via SIP INFO with our Broadsoft platform but I'm running into an issue.
Broadsoft requires two things of the INFO message
1) Content type to be "application/broadsoft"
2) Event (body) to read "event hookflash"
I have been able to customize the content type via the "Hook flash MIME type" parameter (under the voice -> sip tab) but cannot see a way to modify the event body itself.  It currently sends "signal=hf".
Is there a way to modify this behavior so that I can send something besides "signal=hf" in the event body?
-Adam
Below is an example of the INFO message:
INFO sip:SD7hg63-vp9pm6716k56r331npvv6ir0vejof19gpovh8g000842c@192.168.1.252:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 192.168.1.53:5060;branch=z9hG4bK-927d442a
From: "2001 User" <sip:2001@proxy.test>;tag=6b39d0aa55093223o0
To: <sip:2002@proxy.test>;tag=174806386-1375398561300
Call-ID: f2b18c76-60b9c8c7@192.168.1.53
CSeq: 102 INFO
Max-Forwards: 70
User-Agent: Cisco/SPA112-1.3.2(014)
Content-Length: 11
Content-Type: application/broadsoft
Signal=hf
1 REPLY
Community Member
FYI - I'm in touch with Cisco and have verified that what I want cannot currently be done.  I am in the process of working with them on a feature request.
828
