Community Member
Dialing problem with SPA3102
It seems that I have a genuine problem with this ATA devices:
When I connect an old/ordinary wired analong handset (telephone) to it, dialing seems to be working fine.
But - when i connect a Siemens Gigaset, Panasonic or some other handset, the ATA returns a busy signal when I try to dial any number.
Sometimes works when I try to dial manually (inputing numbers slowly), but it never works when the handset autodials a number (dialing from memory)....
I thik it is some regional (Serbia) setting problem (this part is set on the factory default at the moment), regarding the line capacity or some DTMF issue towards the FxO but I'm not sure where to start...
Any ideas?
Community Member
Re: Dialing problem with SPA3102
Just to correct one typo up there - I told i think the problem is towards the FxO port - I was actually thinking of th FxS port of the ATA
Community Member
So, any hints about this?
At least some link to some documentation how to set up the regional settings in the device. The doxs i've found on the installation CD are ridicilous
Edit:
Here's a lof file from the SPA with my problem:
04-20-2010 23:34:03 Local3.Debug 192.168.0.1 [0]On Hook
04-20-2010 23:34:02 Local2.Debug 192.168.0.1 FXO:Stop CNDD
04-20-2010 23:34:02 Local2.Debug 192.168.0.1 AUD:Stop PSTN Tone
04-20-2010 23:34:02 Local3.Debug 192.168.0.1 FXO:On Hook
04-20-2010 23:34:02 Local2.Debug 192.168.0.1 FXO:PSTN Disconnect Tone
04-20-2010 23:34:01 Local2.Debug 192.168.0.1 FXO:Stop CNDD
04-20-2010 23:34:01 Local2.Debug 192.168.0.1 AUD:Stop PSTN Tone
04-20-2010 23:34:01 Local3.Debug 192.168.0.1 FXO:On Hook
04-20-2010 23:34:01 Local2.Debug 192.168.0.1 FXO:PSTN Disconnect Tone
04-20-2010 23:33:57 Local2.Debug 192.168.0.1 2. Report digit 5 (1)(40 ms)
04-20-2010 23:33:56 Local2.Debug 192.168.0.1 2. Report digit 9 (1)(40 ms)
04-20-2010 23:33:56 Local2.Debug 192.168.0.1 2. Report digit 8 (1)(40 ms)
04-20-2010 23:33:56 Local2.Debug 192.168.0.1 2. Report digit 5 (1)(40 ms)
04-20-2010 23:33:56 Local2.Debug 192.168.0.1 2. Report digit 4 (1)(40 ms)
04-20-2010 23:33:55 Local2.Debug 192.168.0.1 2. Report digit 2 (1)(40 ms)
04-20-2010 23:33:55 Local2.Debug 192.168.0.1 2. Report digit 1 (1)(40 ms)
04-20-2010 23:33:55 Local2.Debug 192.168.0.1 2. Report digit 8 (1)(40 ms)
04-20-2010 23:33:55 Local2.Debug 192.168.0.1 2. Report digit 3 (1)(40 ms)
04-20-2010 23:33:55 Local2.Debug 192.168.0.1 2. Report digit 0 (1)(40 ms)
04-20-2010 23:33:54 Local2.Debug 192.168.0.1 2. Report digit 0 (1)(40 ms)
04-20-2010 23:33:51 Local3.Debug 192.168.0.1 [0]Off Hook
It seems that it detects FXO:PSTN Disconnect Tone false.....any ideas now?
771
