Fax speed on SPA122 is too slow !!!
I'm having problem with SPA122 ATA. When customer hear the fax tone, and press start button, it takes about 15 seconds before start sending !!!.
Is there any parameter I can adjust for faster speed.
  • ATAs Gateways and Accessories
1 REPLY
Depending on where you are
Depending on where you are sending the fax, you should be using t38:
https://supportforums.cisco.com/document/126086/spa-ata-fax-t38-basic-configuration
Hope this helps.....
159
