FXO port problem
I have the following situation.
My provider gives me  PSTN connection  though linksys SPA 2102.They  connect SPA 2102 from imy side to their side by sip trunk.
In my side i have router with FXO ports.Now i`m trying to connect my  router`s FXO port to SPA 2102 FXS ports.
I`m truing to make call,but it  fails.Insted of  connecting routers FXO port ,i connect RJ 11 cabel from SPA 2102 to analog phone and make call.It succed.
My ISP said that it possible  to make call from  Routers FXO port connected with SPA2102 FXS port .ISP said that SPA2102 FXS port configured as default.
My topology is as following
Ip phone  -- router FXO port ----  SPA2102 FXS port --- VoIP Provider.
voice-port 0/0/0
caller-id enable
dial-peer voice 41 pots
description Call Local
destination-pattern 2......
port 0/0/0
forward-digits 7
PORT            CH   SIG-TYPE   ADMIN OPER STATUS   STATUS   EC
0/0/0           --  fxo-ls      up    dorm idle     on-hook  y
1 REPLY
FXO port problem
Helo Emin,
Can you collect the following debugs/information and send it over:-
Turn on the following debugs:
1) debug vpm singal
2) debug voice vtsp all
3) debug voice caapi inout
Make a test call
Also send me the show tech from the router. And the calling and called numbers for the call.
161
