How to set NTP with the web GUI on SPA 112 ?
Hi everybody
I don't find how to set the local time nor ntp servers settings on my SPA 112 device.
Here are model hardware and firmware characteristics:
and here is the "network settings" tabI have no tabs under it:
Did I do something wrong, or how can I fix this issue ?
I am 9 hours away from PST time
1 ACCEPTED SOLUTION
VIP Gold
Re: How to set NTP with the web GUI on SPA 112 ?
Forgot firmware version 1.0.2. It is not suitable for production. Upgrade to latest firmware.
SPA ATA Firmware Upgrade Process Explained
If problem will not be solved by upgrade then ask again.
Note:
SPA1xx Firmware Upgrade: No Browse Button
ATA Firmware Upgrade: Browse Button disabled [grayed-out / inactive]
SPA ATA Firmware & Tools
VIP Gold
Note:
In fact it is a shame :
To be able to upgrade the firmare, the user MUST use Internet Explorer of Microsoft.
So what about people who use Firefox or others, or even who don't use windows at all ?
I really think there is something wrong with this
Finally, I had to install a Win7 OS in a VM just to make the upgrade. And everything works fine now.
Anyway thanks to all !
VIP Gold
Not exactly. Manual upgrade using is one method of upgrade, not only method of upgrade. You can use DHCP server for provisioning setup as well. Provisioning can order device to do firmware upgrade.
Fortunately things have moved on:
I just tried with Firefox and the new 1.3.2 firmware and it works, without requiring Internet Explorer any more.
That is the good new, I had to tell it .
Thx
816
