how to upgrade the spa122 firwmare to 1.2.1(004) using configurtion file
Highly appreciate if anyone can let me know how to define the upgrade rule in configruation file to upgrade the firmware to 1.2.1(004) -
is it ok if I define it in upgrade rule as below
<Upgrade_Rule>  (!1.2.1(004))?http://10.1.1.1/SPA112_SPA122_1.2.1_FW.bin  </Upgrade_Rule>
if not, what is the correct one
Denning
  • ATAs Gateways and Accessories
Everyone's tags (3)
VIP Gold
Yes, it's old legacy syntax. The recommended syntax is:
...Rule> ($SWVER != 1.2.1(004))?http ...
Unfortunately, such type of conditional doesn't work reliable most times for me (althougth I didn't tested the particular one from your example).
I don't know why.
I suspect, that firmware numbers like 7.4.9c or 7.5.2b may be source of problem - Cisco's Provisioning guide claim that version numbers take form of three  non-negative numbers separated by periods followed by optional  alphanuberic string in parthenses. It's not true for some released versions. May be, the comparsion logic doesn't handle those broken version numbers correctly.
Would the value maybe be
($SWVER != 1.2.1.004)
That is the firmware version it says when you go in via IVR and do a 150#
From brief experience with this firmware; this rule seems to work:
($SWVER ne 1.2.1)?http://provisioning-server/SPA1xx.bin
Also, by looking at http://SPA122.local/admin/config.xml
Towards the end of the XML config:
1.2.1
004
SPA122
My take is that $SWVER would expand to
VIP Gold
Re: how to upgrade the spa122 firwmare to 1.2.1(004) using confi
before upgrade: SWVER=1.0.1(022)
after upgrade:    SWVER=1.2.1(004)
1244
