05-11-2014 02:06 AM - edited 03-21-2019 10:16 AM
I couldn't connect pc by ethernet cable with spa2102 typing the given ip address 192.168.0.1 so I tried connect via modem-router dialing the command ****7932# but the adapter response was that this is a invalid function or operation.Can somebody give some help?
05-11-2014 04:47 PM
See excerpt from Quick Start Guide on the bottom. Did you followed the "do not press ..." part of it correctly ?
Interactive Voice Response Menu
Action | Command | Choices | Description |
Enter Interactive Voice Response Menu | **** | Use this command to enter the Interactive Voice Response Menu. Do not press any other keys until you hear “Linksys configuration menu. Please enter the option followed by the # (pound) key or hang up to exit.” |
05-11-2014 11:43 PM
I did several resets and now this is fixed but there is no way for me to access the configuration page of spa2102 to set up the PPPoE account with my ISP.I tried ethernet connection and via router with no success.When I ping 192.168.0.1 there are no warnings and in system tray of windows there is the icon of established connection but when connecting to the address internet explorer gives 404 error and firefox a totally blank page!
05-12-2014 12:00 AM
Are you sure you have no OEM/Customized/Restricted version of the unit ? It may be tied to particular operator/configuration and your's access to configuration may be limited or impossible at all.
05-12-2014 01:25 AM
I bought it through a ebay-like site.On the package it is Linksys labeled an the name is spa2102-EU with warranty contract.Maybe I threw my money away?
05-12-2014 02:05 AM
I can't say it for sure. You may call Cisco support with the unit serial number ready, they should tell you.
In the mean time - you claimed you can ping the unit with no problem, but you are unable to connect using the browser. Are you sure your browser is connecting to it ? I have some advanced services in the mind like proxy, antivirus software, SmartScreen-like services. May be your browser didn't tried connection to the unit in the real. Be sure your browser is trying to connect to the unit. Ask your computer administrator for help. Use packet catcher to verify if you are computer administrator and you are not sure about your's browser behavior ...
05-12-2014 05:43 AM
I am really sorry for take your time because I tried with ip:192.168.1.199 and now the setup page shows up.Thanks anyway!
05-12-2014 05:55 AM
No problem, glad to hear.
