Linksys 962 with 932 Attendant Console
Just want to clarify if its possible to do a transfer from 962 to one of the speed dials on the 932 via any lines on 962, as it whats happening on my end is even though Im using say Line 6 on a call, and want to transfer this call via one of the speed dials on 932, for some reason it uses Line 1 all the time to do the transfer.
Hopes it make sense and any help is appreciated.
1 REPLY
Re: Linksys 962 with 932 Attendant Console
Hi jowan.cruz,
What are you using for call-control? SPA9000, trixbox, Asterisk, something else?
Please describe, step-by-step, how you make/receive a call on line 6 and then what you do to transfer the call.
Please also provide the SPA962's config: https://supportforums.cisco.com/docs/DOC-9933
The following may be of interest to you:
Transferring calls: https://supportforums.cisco.com/docs/DOC-9949
Configuring Speed Dial: https://supportforums.cisco.com/docs/DOC-9921
Patrick
2588
