Community Member
linksys pap2: configure british sounding ring
is there a straightforward way to configure the linksys PAP2 to make the phone ring like a normal british phone? you know...ring ring pause) ring ring (pause)...(ie: not the american ring). The documentation I've foind on google regading this is confusing and difficult to understand.
1 ACCEPTED SOLUTION
If you are looking for 0.4 sec on, 0.2 sec off, 0.4 sec on, 2.0 seconds off with the cycle repeated for up to 60 seconds. I believe the cadence specification would be
60(.4/.2,.4/2)
You could try replacing Ring 1 Cadence on the PAP2 Regional Tab with the above.  Be sure to remember what was there originally in case it doesn't work.
60(.4/.2,.4/2)
Community Member
yes that cadence worked great, thanks very much for your help.
941
