Preprovisioning Cisco SPA112
Please tell me how to create a generic configuration file for Cisco SPA112 spa112.cfg file that could upload it to any device for SPA112 for preprovisioning?
Command spc - xml xxx.xml - target aabbccdd1122 spa112.cfg
not true, because the file will only be available with the device MAC address aabbccdd1122.
Thank you for your help.
Everyone's tags (1)
VIP Gold
Duplicate of Preprovisioning
Duplicate of Preprovisioning Cisco SPA112
In advance. wrong forum. SPA112 is not SPA IP Phone, but SPA ATA device
Try this command: spa112-1-3
Try this command: spa112-1-3-3-015-spc-win32-i386.exe --sample-xml preprovisioning_cfg.xml
  spc: generated SPA112 sample configuration preprovisioning_cfg.xml
The file preprovisioning_cfg.xml can be modified with a text editor in order to configure only common or general parameters.
The file can be uploaded to a SPA via HTTP or TFTP server using one of these special urls:
preprovisioning_cfg.xml is shared through TFTP server
 http://SPA_IP_ADDRESS/resync?tftp://TFTP_SERVER/preprovisioning_cfg.xml
preprovisioning_cfg.xml is shared through HTTP server
 http://SPA_IP_ADDRESS/resync?http://HTTP_SERVER/preprovisioning_cfg.xml
Regards.
189
