Problem going off hook with ATA SPA112
I have an SPA 112. I can reigister without problems to my Voip supplier. I can get a wired desk analogue phone (with external power) to go off hook, get dial tone and make calls, BUT when I attach a BT Freestyle 750 DECT phone or a non extrernal powered desk phone to the same line (FXS port) I can not get the phone to go off hook and so can not get dial tone or make calls.  Can someone suggest what the solution to my problem could be ?
Don
1 REPLY
Re: Problem going off hook with ATA SPA112
Check the pinout cable. You must use a 2 wire RJ11 (tip and ring only).
Check "FXS Port Power Limit" value of your SPA under Voice-Regional-Miscellaneous menu'.
Check "FXS Port Polarity Configuration" of SPA under Voice-Line menu'.
Check power supply of SPA.
Regards.
921
