problem: spa2102 line1 receive both line1 & line2 calls
Line 1 has one IP phone service. Line 2 has Gizmo5. When I connect brother mfc845cw fax phone to line1 port. It can receive both line1 and line2 calls. When I connect this fax phone to line2 port, it only receive line2 call. The fax phone has 2-cord phone line, not 4-cord. It is not a 2-line phone. Thanks in advance!
Jay
Everyone's tags (1)
Re: problem: spa2102 line1 receive both line1 & line2 calls
Dear Sir;
This is indeed strange. I would need the following info in order to see if it is a config issue or a bug:
(1) SPA2102 configuration (save the full html file)
(2) Traces or debug information for the device when this happens.
Please send it via a private message.
Alberto
have you confirmed this by using a corded phone device directly to port 1 ?
as I understand from your post you already know that line1 features an AB connection
1356
