Problem with anonymous caller id in spa8000
We have started to migrate our customer from pap2t to spa8000.
Now we got an issue that we need help with.
If we activating CID block (*67) the sip server will deny the INVITE
I think it has to do with from and contact field.
All parts is now anonymous, in pap2t the real number is still in the <>.
Is it possible to change this?
Any Ideas?
My invite looks as following:
INVITE sip:11111111@sip.mydomain.com SIP/2.0
Via: SIP/2.0/UDP 2.2.2.2:5360;branch=z9hG4bK-ff7fa670
From: "Anonymous" <sip:anonymous@localhost>;tag=1fdbc659fb942988o0
To: <sip:11111111@sip.mydomain.com>
Remote-Party-Id: "33333333333" <sip:33333333333@sip.mydomain.com>;screen=yes;privacy=full;party=calling
Call-Id: 612a4f6d-18571384@localhost
Cseq: 101 INVITE
Max-Forwards: 70
Contact: "Anonymous" <sip:anonymous@2.2.2.2:5360>
Expires: 240
User-Agent: Linksys/SPA8000-6.1.12
Allow-Events: talk, hold, conference
Content-Length: 444
Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER
Supported: x-sipura, replaces
Content-Type: application/sdp
Date: Mon, 02 Dec 2013 15:29:48 GMT
with pap2t is look like this:
INVITE sip:111111111@sip.mydomain.se SIP/2.0
Via: SIP/2.0/UDP 3.3.3.3:5061;branch=z9hG4bK-1ff53e0
From: Anonymous <sip:22222229@sip.mydomain.se>;tag=c0bc166c356c37ffo1
To: <sip:111111111@sip.mydomain.se>
Call-Id: 8d9cc4b0-68e7be8b@localhost
Cseq: 101 INVITE
Max-Forwards: 70
Contact: Anonymous <sip:22222229@3.3.3.3:5061>
Expires: 240
User-Agent: Linksys/PAP2T-5.1.6(LS)
Content-Length: 438
Date: Mon, 02 Dec 2013 19:01:54 GMT
//N
  • ATAs Gateways and Accessories
Everyone's tags (1)
1 ACCEPTED SOLUTION
VIP Gold
Re: Problem with anonymous caller id in spa8000
Just to be sure - do you know you are replacing one end-of-life platform (PAP2T) with another end-of-life device (SPA8000) ?
But back your question.
Your's PAP2T's INVITE has no CLIR active. Caller number is present in both From: and Contact: header, there is no Privacy: Id nor Remote-Party-Id.
So, next-step exchanges know nothing about CLIR and caller's number is transferred to called phone with no restrictions.
On oposite side, SPA8000's invite claim CLIR using Remote-Party-Id method. But your's SIP gateway is rejecting such call.
You either have no right to use CLIR or particular SIP gateway is configured to use other way to request CLIR Remote-Party-Id. Or the CLIR CALL request is rejected somewhere on the path to destination.
Simplest solution ? It seems that CLIR did not worked on your's former network correctly and caller's number has been delivered to called user with no restriction. So disable CLIR service on SPA8000. No functionality will be lost.
Message was edited by: Dan Lukes (SPA8000 is not EOL)
VIP Gold
After I diabled the "Remote-Party-Id" is work fine.
Dan,
Where have you seen an EOL for the SPA8000?
I searched and have not found one.
http://www.cisco.com/en/US/products/ps10024/prod_eol_notices_list.html
VIP Gold
You hit. My mistake, it's not true.
Just bought 8 of them, glad they are not EOL.
1124
