RJ-21 Port on SPA8800
Can anyone tell me if the RJ-21 port on the SPA8800 is male or female?
Jason Komar
Everyone's tags (2)
1 ACCEPTED SOLUTION
Re: RJ-21 Port on SPA8800
How you can see in the image below the RJ21 amphenol is female.
Regards.
4 ports are FXS and 4 ports are FXO
FXS means Foreign eXchange Subscriber. It delivers POTS service and must be connected to subscriber equipment (telephones, modems, and fax)
FXO means Foreign eXchange Office. It receives POTS service, typically from a Public Switched Telephone Network (PSTN). An FXO interface points to the Telco.
Regards.
Thanks for the reply, but I did realize that. The FXO and FXS ports are RJ-11 connections.
I am wondering about the RJ-21 (50-pin telco connector) multiport voice connection: whether it is a male or female connector. I have one on its way to a client and I need to purchase the correct cable to wire it into their patch panel.
Jason
Regards.
Thanks for your help.
Jason
1847
